Open entities
Open entities
jmartinez181JWQRD
Open entities
jmartinez181JWQRD
Hi I'm very new to all of this, I created a design on fusion360 and when I upload it to send cut send it says theres open entities but I just made the design out of one circle and extruded it. Any help or feedback would be greatly appreciated, thank you.
J.Martin
jhackney1972
Export the Fusion Native file in STEP format and the Service SendCutSend will have not trouble accepting it.  You go to the File Menu, select Export and then select STEP as the format.  I exported it for you if you would like to use it.
By the way, next time you post a question be sure to be "descriptive" in what you desire.  Some individuals may not know what "SendCutSend" service is.
John Hackney, Retired
Warmingup1953
By what method and materials will this be manufactured? Machined from solid bar stock? What is it?
bwalker145
As John mentioned, export as STEP and there's no issue uploading to SendCutSend.
That's going to be a pricey little cap though....
