Opacity Control in Simulation not working
steveCSNTC
steveCSNTC
New to fusion 360 but many years of ANSYS use. I'm trying to get a simulation setup going using thermal + structural stresses for conformal cooling passages and cannot view the internal passages without the component being transparent. Is opacity control not available in simulation?
I right click on the body level, component level, and assembly level while in the simulation space and none have an opacity control menu selection.
I've attempted to create separate cut planes, but unfortunately the analysis item doesn't carry between Design <> Simulation.
I've also tried adjusting all the bodies/components to 100% opacity in design, hopped back into simulation, and then separately adjusting opacity at the body or component level and hopping back into simulation with no luck.
Basic functionaly in fusion is crushing productivity. Thank sweet little baby jesus we finally have a good measurement too with a recent update.
Any ideas on this problem?
alessandro.gasso
You can control the component opacity for the Simulation in the Simplify environment as shown in the video below.
https://autode.sk/3k8Tplc
I hope it helps.
Alessandro Gasso
Fusion 360 – Simulation/Generative Design Adoption Specialist
Autodesk, Inc.
