Howdy all, Last time i needed help on here you guys were awesome, and its a similar thing i need help with.
Im trying to make a shell to put a led bar in for a scale street lamp and im trying to loft the top of it so its a nice shape.
The sketch for the x axis of the loft is fully constrained and has no problem, but my sketch on the z axis wont constrain for some reason, so when i go to loft i get a " The operation failed. Try adjusting the values or changing the input geometry", all the lines are intersecting from what i can tell but im getting this problem
I have attached the f3d file for this project. im not sure what im doing wrong but its something and i cant work it out or found a solution when searching.
Thank you very much and hope you all have a good day!
