One Sketch wont constrain and cant loft Help
Lunar.Wolf.Works
Message 1 of 19
Lunar.Wolf.Works
Howdy all, Last time i needed help on here you guys were awesome, and its a similar thing i need help with.
Im trying to make a shell to put a led bar in for a scale street lamp and im trying to loft the top of it so its a nice shape.
The sketch for the x axis of the loft is fully constrained and has no problem, but my sketch on the z axis wont constrain for some reason, so when i go to loft i get a " The operation failed. Try adjusting the values or changing the input geometry", all the lines are intersecting from what i can tell but im getting this problem
I have attached the f3d file for this project. im not sure what im doing wrong but its something and i cant work it out or found a solution when searching.
Thank you very much and hope you all have a good day!
Replies (18)
Message 2 of 19
Lunar.Wolf.Works
Ive got it now so that both sketches are constrained but still getting the loft error, File is attatched
Message 3 of 19
Lunar.Wolf.Works
Message 4 of 19
laughingcreek
rails have to be curvature continuous.  the profile of the body you are using as the rail comes to a point at each end.  in the attached I added a center line to sketch 20 and changed the profiles I picked for the loft to get it to work.
Message 5 of 19
Lunar.Wolf.Works
Ahh so i need a continuous curve to make it work? you've used the upright curve as the rail instead of the perimeter like i was trying to? Thank you very much for the help, Are their many videos on these kind of things or are you well versed in fusion?
Message 6 of 19
etfrench
I'd vote for well versed 😁
ETFrench
Message 7 of 19
Lunar.Wolf.Works
Ive tried to do it myself from using the profiles you have used but it will not work, it gives me errors
Message 8 of 19
Lunar.Wolf.Works
Ive had to alter the design so i went back quite a lot of steps and followed what you have done but nothing wants to work for some reason
Message 9 of 19
Lunar.Wolf.Works
Attached i have the file, i have to have the back piece square to put a 10mm hole on the left plane. even when i use the file you did and de select and re select the profiles it wont loft, im not sure what im doing wrong, would it be best to do a screen cast?
Message 10 of 19
Lunar.Wolf.Works
forgot to tag u in new comment
Message 11 of 19
g-andresen
maybe that's the reason > deselect!
günther
Message 12 of 19
Lunar.Wolf.Works
Added screen cast
Message 13 of 19
Lunar.Wolf.Works
tried but didnt make a difference on the one old mate did for me, i had to select one side then the upright profile then the otherside,not on my new model its saying that rails cant be tangent to profiles,
Message 14 of 19
davebYYPCU
No access to your file for a few hours yet, but first thing I saw in the video, is what looks like an attempt to Loft with hollow or incomplete profile 1.
Try building one profile that closes the square opening.
Might help....
Message 15 of 19
Lunar.Wolf.Works
no problem, yeah i got the back bit lofted but cant get the front half lofted, now its saying one or more rails intersect a profile more then once, try adjusting the sections to avoid this, or now its saying cannot be tangent to profiles
Message 16 of 19
g-andresen
I see this:
günther
Message 17 of 19
davebYYPCU
Yeah, I thought so,
@Lunar.Wolf.Works  build full profile to the centre line, because Loft can not do a hollow type of profile.  Especially as the profile 1 and 3 are at 180 degrees apart.
Message 18 of 19
Lunar.Wolf.Works
I feel dumb now 😂, Thank you very much for the help, will note for next time can loft hollows
Message 19 of 19
davebYYPCU
No Sir,
much better to ask, than to fumble around - and never know why.
