One body but seems two selections - Extrude to object error
lorinczmatecsaba
lorinczmatecsaba
Community Visitor
Community Visitor
Dears,
So im kinda newbie, but here is what i need help with please. There is a body that made from centered circles that been Lofted. The loft needed to be done in too parts for the required result of body shape (I can do the body with Revolve too but it even worse when extruding). After making this loft, i have splitted the body to different bodies.
I would like to do some Extrude to Object option, just like on the picture, but when i need to select an "Object" the so called "Nose" body seems to made of 2 parts, but it is one body. And when i try to do the Extrude , i can only select one part of this body, no matter that it is actually one body. I tried the combine function but it still does not change, also tried to make the body with sketch and to Revolve, but the result is even worse since more "break points".
Any solution on this?
laughingcreek
extend to from "start" is limited in functionality.
instead use "extend type"
you can only select one object at a time.  if you select from the modeling space, you can only select faces and sketch objects.  if you select a face you will get this option-
which will do what you're looking for.
you can also select the body, but you have to do it from the browser.
