Offset plane not joining
skipb48
skipb48
I am designing a sleeve for a cup holder to match a Yeti and when I look at it infusion, it looks all right, but when I slice it in Cura, the top part is not joined to the lower part. I'm assuming I did something wrong in fusion?
jhackney1972
If you create a Section Analysis through your model, you will see the problem.
EDIT:  Attached is your model with a "little meat" joining the side wall to the top.  I use 1mm but you can edit it if desire.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
skipb48
Wow, now I see several problems with it. I was not aware of section analysis as I have not messed with inspect menu before. Sorry about the length of time I'm getting back to you, but I was called out of town last week and only today was able to get back online with this.
Thank you for your very helpful response
