Carve/Engrave/Emboss using height map for 3D print
rglorieux
rglorieux
Community Visitor
Community Visitor
Hey everybody,
I have an already made object that I would like to carve/engrave/emboss an image onto the surface so that there is geometric data when I export the object as an STL file. I have already created a solid from a heightmap (using the Surface2Image plugin, and converting the mesh), but I am unsure what operation to use to create actual geometry on the object. The object its self is in two parts and I need to keep them from fusing together.
I am currently working with limited computational power, which has resulted in long wait times due to how many faces I need to select at one time.
Thank you in advance for any help.
CGBenner
@rglorieux
Hello and welcome!  Would it be possible to share your file in this forum so the experts can take a look?
Chris Benner
johnsonshiue
Hi! If I understand you request correctly, I suspect you are looking for Texture Extrude command. To enable TE, you will need to change the edit mode to Direct Edit. In the Mesh Design environment, right-click on the top node in the browser -> scroll to the bottom -> Change to Direct Edit. After that, go to Modify tab -> Texture Extrude. TE command allows you to select an image and protrude mesh according to the grey levels.
Many thanks!
Software Test Engineer
CGBenner
@rglorieux
Did the information provided answer your question? If so, please use Accept Solution so that others may find this in the future. Thank you very much!
Chris Benner
