offset multiple lines
I am a beginner with a mac and I am trying to offset half of bottle neck . I projected the sketch using the front view and then drew lines  to link the points on half of the sketch. When I tried to offset the lines to include the entire half of the sketch I was unable to include all the lines in the offset. Sometimes only one line would offset and others I could include several. What would be the cause for this error?
dan.banach
Hi, To offset multiple entities, the geometry needs to be connected with a Coincident constraint (the endpoints are connected) and check the "Chain Selection" option in the Offset dialog box. If the entities are not connected, you'll need to offset them individually. This would be a good suggestion for the Fusion 360 IdeaStation.
Hope this helps.
-Dan
Dan Banach
Sr. Technical Manager & Community Manager
If my post resolves your issue, please click the Accept Solution button.
Do I choose coincident restraint and then click on all the lines to connect
them?
dan.banach
Correct, click the Coincident Constraint from the Sketch Palette, and then select 2 endpoints. This will connect the selected points.
Dan Banach
I am a beginner, enough said. I am trying to get the offset multiple to work.  I have reviewed this issue with 4 different tutorials, all the same instructions nothing works.  The Offset multiple function does not display the doted line indicating where the copy will go to.  I have completed the following commands
Offset
distance
select object to offset
M for multiple
then it asks for a point or exit.... Then I get a vertical y axis line.  Their is no doted line which would designate where your multiple item would go.
I must be missing something very basic but after 3 hours I can not figure it out.
Written in haste, Ann
etfrench
What do you mean by Offset Multiple? In the Model workspace, you can offset multiple sketch items as long as their endpoints are coincident. You can't offset one item to create multiple offset instances of that item in one command.  You can create multiple offsets of a single item in multiple commands.
ETFrench
jaydenjbg
Community Visitor
Community Visitor
There is another way other than using the coincident tool.
  1. Hold down the control key and select all the lines and curves you want to offset
  2. Right click
  3. Click the dropdown "Sketch" tab
  4. Click offset
  5. Set your desired values
  6. Click ok; or if it doesn't allow you to, then select another tool to switch it off of the offset
