Offset feature not giving wanted result
stbloemen
stbloemen
I'm trying to design a puzzle model via a .svg file
Using the offset feature, I give every line a 0,3mm offset.
When trying to extrude the puzzle pieces, some are merged together and result in wrong extruded puzzle.
I found that using the offset feature, not every line is connected / passes the outside line.
I was able to fix it by simple extending the offsetline with a normal line that crosses the outside line,
however this takes too much time, doing this for every line in every puzzle.
My question: Is there a better way of achieving a correctly sliced puzzle? And what method / fix should I use?
Thank you for your time
TheCADWhisperer
My first thought would be to use Thin Feature Extrude rather than offset sketch.
Now let me give it a try...
First I tried one-by-one and then in the last extrusion I did all the remaining pieces at once.
stbloemen
Thank you very much, a simple but effective method. Just what I needed.
