Offset doesn't recognize squares
I am trying to offset squares I draw to make windows but it doesn't seem to work.
Any idea on the process I should follow ?
Picture on left represents the squares selected, pictures on right shows that offset only recognize one line at a time (chain selection isn't checked)
Guillaume
g-andresen
first you need lines representing one side of the square .
Then use hold shift & select to select the lines for the offset.
günther
chrisplyler
He thinks he should be able to offset multiple closed loops in one shot. AND he thinks it should work even if those closed loops SHARE elements.
To the OP... How do you expect Fusion to offset the common lines in two directions at once, while knowing that the other lines only need to be offset in one direction? You're asking for a lot more complexity that this simple tool is capable of.
MRWakefield
Is this the kind of thing you're looking for?
I'm still having problems with attaching a screencast so here's a link: https://autode.sk/2SDe3yd
If this answers your question please mark the thread as solved as it can help others find solutions in the future.
Marcus Wakefield
____________________________________________________________________________________
I've created a Windows application (and now Mac as well) for creating custom thread files for Fusion. You can find out about it here. Hope you find it useful.
If you need to know how to offset threads for 3D printing then I've created a guide here which you might find useful.
If you would like to send me a tip for any help I've provided or for any of my software applications you've found useful, you can do this via my Ko-Fi page here.
Ok thank you, for the record I am used to sketchup which automatically considers 2 intersecting lines as 4 different lines making the offset way easier.
It comes handy when you have to make tons of offset, for exemple when making a stone wall.
Thanks for this tips, it is quite smart 🙂
