Odd crashes after since the last update!
Beyondforce
Advisor Advisor
Beyondforce
I'm experiencing odd crashes since the last update. e.g. I have tried to move a Sketch from one component to another, then Fusion crashed.
It is the 4th time it crashes since the last update. I have noticed that I'm not the only one experiencing the crashes. If it's a known issue, I hope next update will fix it.
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
brianrepp
Hey Ben - have you been getting and sending in CER's for these?  We did a quick search for CER's submitted under your email and aren't seeing any in the past 30 days.  If you're using another email for Fusion, do you mind PM'ing or emailing me (brian dot repp at autodesk.com)?
Beyondforce
Hi Brian,
What do you mean CER? The pop-up after the crash?
Ben Korez
| YouTube
brianrepp
Yes, exactly, I shouldn't have used the acronym - it is the Crash Error Report, which helps us diagnose crashes in order to fix. Curious, are you also using CAM environment?
Beyondforce
This time there was nothing, but if it happens again with the CER, I'll make sure to send it.
Thanks.
Ben Korez
| YouTube
brianrepp
Thanks, Ben - let me know when/if it does happen.
