Objects are invisible in Simulation Mode
I have been attempting to conduct a Finite Element Analysis on a second configuration of a 3-D printer subassembly I am attempting to design. The first iteration has been conducted successfully and had no problems. The components/objects of the second iteration seem to disappear as soon as I change to simulation mode to select a study type. The only visible elements are the work planes whose visibility checkboxes remain selected. The difference between the two different situations is present even when selecting between one assembly and another instantly across the tabs at the top.
Naturally this is extremely frustrating as it is impossible to constrain any faces or apply loads when your objects/components are invisible.
I have attached screenshots of both assembly iterations, one where the components are working, and the other with the components invisible, with all ostensible conditions kept the same.
Does anyone know what could be different between the two runs and what can be done to solve it?
Screen Shot 2017-11-19 at 6.37.43 PM.pngScreen Shot 2017-11-19 at 6.37.35 PM.png
Hii Harvester,
You should Attach your design for understand Properly and that to be continued...
For giving answer for you problem which is comes in your Project.
