Object export
Object export
billbedford
Object export
billbedford
I'm trying to produce a coloured 3D model to be printed on a Mimaki machine. I've built the model and have rendered it in Fusion with no problems. When I export it to an OBJ file the .obj part looks OK, but the .mtl file is essentially empty:
# WaveFront *.mtl file (generated by Autodesk ATF)
newmtl Planks_3
Kd 0.000000 0.000000 0.000000
newmtl GN_Wagon_Brown
newmtl GN_Lettering_(1)
newmtl Shadows
newmtl Planks_1
newmtl Planks_2
newmtl Planks_4
Can anyone suggest what is happening and what I can do to get pretty coloured models?
HughesTooling
Just did a quick test adding a colour and get this.
I've attached my Fusion design.
How have you added the colours to your model, can you share the design?
Mark Hughes
Owner, Hughes Tooling
billbedford
Hi
Thanks for the file. The problem seems to be that the bureau I'm using wants texture maps for each of the colours. I've tried to set these up in Fusion but their information is not being added to the .mtl file.
Here's the file:
HughesTooling
@TrippyLighting Might have some advice.
Mark Hughes
TrippyLighting
I don't think Fusion supports exports of appearance materials including texture map for .obj, or .fbx formats. At least I can se no trace of those in Blender.
For .usdz that does seem to work. I can see the diffuse, roughness and normal map in Blender, but have to tinker around with it a bit to make it useful in the 3D viewport.
The basic data appears to be present.
So a possible workflow would be to export the file to .usdz file, import it into Blender and export it from there into a .obj file.
I have not toed if that actually works in the sense that such a .obj file would then contain the textures.
