Bring two bodies (or components) parallel to each other and really close
rpsalas
rpsalas
Two simple bodies. I want to move the top one very close but not touching the second one and I want to set a known distance, say 0.6mm. Just moving it by hand is trial and error. So I thought, a joint! But I am confused by the options for the joint. I assume I want a simple joint, which will be rigid and have one of the three dimensions set to 0.6 and the others to 0. I want the center point of both squares to coincide. But there is no point on the top body in that spot.
kacper.suchomski
Hi
You can use constraints.
https://help.autodesk.com/view/fusion360/ENU/?guid=ASM-CONSTRAIN-COMPONENTS
Kacper Suchomski
Drewpan
Using the two bodies in the image as an example there a couple of ways that
you can do this accurately. While the Move command can work here it is not
commonly recommended as a solution for many reasons.
The first method I would use and is the simplest would be to draw both of these
shapes on a single plane and then use the Extrude command.
The end result is two objects that are 0.6mm apart.
Another method, and not the only method, is to use a standard
Plane for your first sketch and create an Offset Plane for the other
Sketch.
Both methods will work. Both methods have their advantages and
disadvantages.
Cheers
Andrew
