Object disappears while converting .Stl to Iges
Hi All,
I am new to this forum . I am trying to convert certain .stl files to .Iges. As described else where in the forum I go to" Create" and create the base feature and go till the end of the steps at the But unfortunately at the last step when I click "Capture Design History" the 3d Image disappears.
It doesn't happen always, but happens many times. I convert the .stl file using "Meshmixer" to .obj file and then uses "Instant Meshes" and convert the mesh to quads. In fusion I see the 3d object as quads in the golden color. I read some where that the T Splines when they form makes a very smooth object but that does not happen in the cases where the object disappears. I really doubt if the T Splines are not forming atall. In those cases where the object is smooth the object does not disappear.
Thanks in in advance,
