NPT threads to .stl
NPT threads to .stl
joehollinger
Message 1 of 13
NPT threads to .stl
joehollinger
I know that fusion has trouble with NPT threads, but I was surprised to learn that it can't export NPT threads. Is this a known thing?
Replies (12)
Message 2 of 13
dsouzasujay
Hi @joehollinger ,
Could you please create and share a screencast/video of what you are doing?
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
Message 3 of 13
Bunga777
I see that taper screws cannot be modeled at this time.
Although not a taper screw, someone has provided a definition file in straight so that NPT can be modeled.
https://www.thingiverse.com/thing:2700822
You can model straight NPT screws by downloading the file from here and saving it to this location.
%localappdata%\Autodesk\webdeploy\Production\version ID\Fusion\Server\Fusion\Configuration\ThreadData
With this method, you have to repeat the same thing every time you update the file or the definition file will revert to the original, but if you must, this method is also possible.
Message 4 of 13
Warmingup1953
I think I'm right that Fusion 360 has NO preset for NPT or what I call NPTT (Tapered threads.).
Message 5 of 13
joehollinger
Why? I'm just trying to add NPT threads to a hole and then export the part as an .STL. The same exact thing happens on any hole that uses tapered threads.
Message 6 of 13
Warmingup1953
Are you using the Thread Command?
Message 7 of 13
Bunga777
Currently, even with Thread Cmmand, tapered threads cannot be modeled.
Find a workaround.
What about inserting a part from McMaster?
It is not a fundamental solution, but it is a handy workaround.
I recorded the operation, please watch.
https://knowledge.autodesk.com/community/screencast/82872b57-ff41-4966-b99f-e27c317b79bc
Message 8 of 13
joehollinger
That's what I wound up doing.  As you've noted, its less than ideal. But even if that is the only solution, fusion should tell you that NPT is not supported. It shouldn't show threads in your model and silently refuse to create a correct .STL.
Message 9 of 13
Warmingup1953
Are you using the Thread Command? If so what thread were you specifying?
Message 10 of 13
joehollinger
Yes. 1/2" NPT.
Message 11 of 13
Warmingup1953
Weird! I don't have any NPT as a thread available in Create Thread.
Message 12 of 13
joehollinger
Sorry, hole command. It should show up if you specific tapered threads.
Message 13 of 13
Warmingup1953
Ah I see...The Hole command with thread option contains both threads you can check the "Model" box and those you cant I see.
