NPT pipe threads (new hole wizard)
htulrich
Message 1 of 127
htulrich
Looking through the options on a the new hole creation tool I see all types of pipe threads except NPT.  There are Bsp pipe threads but not Npt? am I missing something?
Replies (126)
Message 41 of 127
chrisplyler
Until such time as they get this functionality in place, I'll suggest stopping by your local plumbing supply shop and picking up a cheap NPT threading tool. If you're going to be 3D printing a lot of things that will require such threads.
Message 42 of 127
This works! Thanks, goldschmidtb Sometimes it really pays to read through all the posts on a thread - someone will offer an answer and simply move on. Here's some screen shots. This should work for the time being for anyone needing NPT threads. Use the align tool to center with your hole and combine (cut) to create your threads. These are modeled and will print.
(In case this solution is separated - use the insert function to import a McMaster-Carr part, use it to create your threads)
All the best, Don
Message 43 of 127
brittonholland
I did this as well.  See message 37 of this thread.  I have also 3d printed the threads and they worked.  I scaled my model up 1% to get a better fit.  The Carr McMaster designs are not always 100% to scale.
Message 44 of 127
spbriggs100
This is a joke. Considering this is supposed to be the end all be all of CAD/CAM software and what you charge for it's use. Here it is almost the end of May 2020. Still no male threads for NTP.
Message 45 of 127
etfrench
What do you think insulting Autodesk in your very first post will accomplish?  Have you actually tried any of the workarounds in this thread?
p.s.  Free doesn't seem to be an excessive charge for the software 😀
ETFrench
Message 46 of 127
spbriggs100
Take as an insult if you like, however it is the truth. White Knight all you want, I don't feel you have accomplished anything trying to reprimand me for voicing my opinion of this software. Definitely will not get a purchase so I did accomplish that with this kind of response from you. Frankly I don't believe Autodesk really cares all that much. I am glad a few years back I convinced the engineering department to switch to Pro-E (Now Creo) and they never looked back.
Cheers
Message 47 of 127
etfrench
I can't speak for Autodesk as I don't work for them.  Basing your purchase on a forum post or on a minor element of the software seems a bit short sighted.  One has only to view the Gallery to see what can be done by people willing to spend the time to learn how to use Fusion 360.
ETFrench
Message 48 of 127
LiveLover
Hello, Jake!
2 years gone, can we use NPT threads now? Or how should we make thread we need in 2020?
Message 49 of 127
this might help people:
https://www.thingiverse.com/thing:2700822
Message 50 of 127
Guess the price hike wasn't enough for them to add NPT.
Message 51 of 127
automationstar
Yep, I've used AutoCAD for the better part of 25 years, and have to agree with you. Autodesk used to be the premier drafting software provider, and OWNED the market for about 1/2 that time, but they have been slipping badly over the last 10 years in my opinion. It seems most of the bug fixes are for only performing updates to keep the software working due to other factors they cant control, like Microsoft updates for example. Their software is now dated compared to many competitors in the 3D Machining, piping, Cabling and Electrical Plant design. Autodesk is trying to patch together 3-4 different software packages, whereas other companies have an advantage of creating an all encompassing new integrated software fresh from the ground up. Pipe threads? it wont happen until a major account screams bloody murder to get it added. As for pipe threads
Message 52 of 127
automationstar
Case in point, NPT threads and I just tried to export out of F360 with a backslash / in the file name, it didnt stop me until it tried to save the file, then failed the export.  No warnings, no explanation, nothing....
Message 53 of 127
Hey everybody. I needed NPT threads on a part I'm about to 3D print. I came here expecting a solution but none were presented yet, so I thought I'd let you know how I made it happen.
All I did was go to McMaster and download a CAD file of a part with the threads I needed (in this case I downloaded a 3/8 x 1/4 NPT straight reducer). Then I just started removing features from the reducer until it was left with a threaded blank:
I made a hole in my main component where I needed these threads, alligned the threads with the hole, and combined the two geometries. Now I have the NPT threads I need and I can get to 3D printing.
It's a little unorthodox, but it absolutely works. Who wants to sit through a tutorial on manually cutting tapered NPT threads?
Good Luck,
Zach Martin
Message 54 of 127
Hi zach, i think you missed my post
https://forums.autodesk.com/t5/fusion-360-design-validate/npt-pipe-threads-new-hole-wizard/m-p/96552...
has the XML file to drop into one of Fusion 360's folders and then NPT will show up. worked fine for me, i created an adapter for a rainbarrel with it.
nice work around though 🙂
Message 55 of 127
Except... the Thingiverse XML file is non-tapered. The McMaster Carr trick did the job for me too! Great recommendation!
Message 56 of 127
jhackney1972
Attached is a parametric NPT plug body that can be change to any NPT thread you need by changing the values in the parametric table.  All you have to do is find a reliable NPT thread table such as this one.  The body can then be used along with the Combine command to create internal or external threads.  I do not warranty it in anyway, I just offer the same thing I download from the forum many moons ago.
John Hackney, Retired
Message 57 of 127
But the point is you shouldn't have to. If I buy a tool for a job, I shouldn't have to use another tool to make the first tool function properly. Stop making excuses for them.
Message 58 of 127
Work-arounds are not excuses. The complaint has been made, a work-around has been supplied by the community.  andrewsjunk: if anyone should stop doing something, it's you. You should stop issuing orders to others. If you don't like the work-around, don't use it.
Message 59 of 127
etfrench
Do you usually buy tools without knowing what they do?  Perhaps some remedial RTFM would do you well.
ETFrench
Message 60 of 127
george.oram
Observer
Observer
Are the NPT threads available yet? I cannot find them almost 2 years after an Autodesk post to say they are coming soon.....
George
