Not sure how to classify this
So I have been working on this project for sometime now, and recently a piece of my project has gone missing. Autodesk didn’t save the changes I made or something. So I’ve been trying to re-make what it is I had and attaching it to a separate cylinder. Now I can’t for the life of me figure out how to combine the two objects.
Basically what I’m trying to do here is to attach a cap with slots in it, onto the pipe (cylinder). When I go to thicken the cap to 2mm it does so, but it also creates empty faces for the inside of the slots. I can’t seem to close those faces off or finish for because it mentions welding? All I want is a 2mm thick/ 1cm tall cap with 4 slots in it and to combine that cap onto the cylinder making it a singular unit. Please help I need this done asap. Thank you!
JamieGilchrist
can you post a picture of what you are trying to do?
jamie.
hope this helps,
Jamie Gilchrist
Senior Principal Experience Designer
