Not possible to Undo Unselectable - BUG
Firstly, I don't now if this is the correct place for this Bug report, so please reclassify if necessary.
After I put a component as Unselectable by righ click direct at the componente, I can not undo this. Even on list of parts, I put the same component as Unselectable and Selectable and it remains unselectable allways.
whittakerdw
Are you able to make it selectable again by clicking on the component in the model tree and clicking selectable/unselectable? You won't be able to make it selectable again by directly clicking on the component since it is already unselectable. I have tried to recreate this issue and its working fine for me. If this is not the issue, can you file=>export your file as an .f3d file and attach it here?
jeff_strater
@fabioluiz.toth - this seems to work for me just fine, at least on a small test design.  I can make either a body or component unselectable, and undo makes it selectable, and redo makes it unselectable again.  I also tried the other way - making an unselectable component selectable again, and this seems to work OK with undo/redo:
Jeff Strater
Engineering Director
Hello Guys,
So when I refer to undo, it is not through the Undo Arrow. I mean make it again selectable since I have made several commands after that, so the arrow would not be a valid option.
Maybe it's working with yours because it's the software for MAC. I use Windows 10.
Follow a demo video.
whittakerdw
Okay now that I see you have components and not just bodies I understand what is going on. Though you have made the component selectable again, the body that is in that component is still unselectable. Click the drop down arrow beside the component you are trying to make selectable again and you will see the body is still unselectable. Right click and make that selectable and that should work for you.
whittakerdw
And the bad thing is, is that you said it was a component and I still missed it. That was my fault sorry about that.
Wow.. Very Nice.. It Works..
So it isn't a Bug, but maybe a suggestion of improve.
Any way.. really Thank you..
Have a nice day!
