Not allowed to select the Component in Create Flat Pattern file from STEP
CLmoss
CLmoss
I think I found a problem with Sheet Metal.
1) I created a sheet metal component in fusion 360
2) I created a Flat Pattern from the component
3) I exited the Flat Pattern
4) I exported the component to a STEP file
5) For this test, I made a component from file in a new folder.
6) I enabled Save History and selected Sheet Metal for this component
7) I tried to create a Flat Pattern from the component again.
8) I was not allowed to select the component in the Create Flat Pattern process.
That is a problem.
If I sent these STEP files to someone running Solid Works, I think they will not be able to flatten these STEP files.
In fact, I cannot unfold these Sheet Metal components made from my STEP files in Fusion.
Jim
daniel_lyall
I don't think they have added this in yet, I did your steps to inventor it did not work ever, I have to look back through I think it was working in inventor I cant rember.
Daniel Lyall
The Big Boss
Mach3 User
Facebook | Twitter | LinkedIn
CLmoss
I wonder if SolidWorks can do it?  I will have the shop check in the next few days.  I didn't try exporting to STEP as a flattened file. I exported to STEP as a unflattened, flattened file.  Maybe that might be different.
Thanks for your help Daniel.
CLmoss
Is it possible to output a DXF file from the original flattened Sheet Metal component in Fusion?  If so, I can't find the command.  Do you know where it is?
