Not all text selectable on SVG import
I created a vector drawling with inkscape, but when I import it to 360 a few of the letters aren't selectable.
I attached a screenshot, the R and I aren't creating a vector or something? I'm new to importing pictures to 360.
I want to extrude this image on an object.
g-andresen
find & repair gaps or unclosed vectors!
That´s a "normal" process during importing such graphic.
günther
Screencast
jeff_strater
this can be a problem with SVG, as they are sometimes inaccurate.  In general, use the "divide an conquer" approach to find the problem areas:  find-leak-in-sketch-geometry .  Looking at the R, you can kinda see how it works:
zooming in, we can see that the problem is in the left hand lower part:
in this case, there is not really a "leak" here, but what I suspect is a degenerate curve:
I just traced over it with a fit point spline, and then deleted the bad curve underneath:
and, it seems to work OK now:
Jeff Strater
Engineering Director
Thank you. This worked and helped me learn a new skill in 360.
