Not able to select profile
colinNJB25
colinNJB25
This happens every once and awhile and normally redrawing the shape or restarting Fusion fixes it. This time I am stuck. I draw a triangle and try to extrude it. Here is a zoom grab of it.
https://us04web.zoom.us/clips/share/BHVzMDQgrW_3s5uWyovRAgHRKj9-MKnB4LTFxaMC4IW7OWN3A6Y
jeff_strater
profiles are turned off in this sketch
Jeff Strater
Engineering Director
jhackney1972
Return to your sketch and check the Profiles box in the Sketch Palette.  You will be able to select it after that for the extrusion process or whatever you want to do.
John Hackney, Retired
colinNJB25
Thank you! I knew it should be easy.
