Not Able to Join in the correct position
I have two Chassis rails. I am trying to put in a bush in for the Axle. when I create the bush and use joints to locate it in the correct position, all ok now when I make one there is also another one appear, that's good,  I try to turn the bush around, but doing so the other bush also moves even though they are separate components  , its like a yoyo affect, is there something I'm doing wrong.. help in this would be great,
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post.
günther
jeff_strater
I see two possible things you are doing wrong here:
  1. You are probably using Move to "try to turn the bush around".  Don't use Move.  Create another Joint on the second instant of that component.
  2. When you are using Move, you have the type set to Bodies, not Components
    When you Move a Body, you are moving that Body inside the Component, so all instances reflect that change.  If you Move the Component, only that instance will be affected
Jeff Strater
Engineering Director
Hi there. I tried what you mentioned and yes it did work fine. Just something else I have learnt. Thanks for your advice. Much appreciated.
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
