Hello guys. Iam not able to create fillet on one edge (picture and project attached). I was able to create fillet successfully on other similar components in project, but this one is out of my knowledge why. I know fillets and loft feature dont go together to much, but that loft is just simple lines and a few rounded corners, nothing crazy.
Do you guys have some idea how to create fillet on that component, any ideas welcome.
Thank you so much for your time and help.
Solved by TrippyLighting. Go to Solution.
Solved by wersy. Go to Solution.
Thank you so much for help. That looks like it could work. Is there some way to modify variable fillet edge selection when tangent chain does not do what you want, are you able to pick for variable fillet just two standalone edge?
Thanks again.
In addition to the start and end points, you can set any number of points in between and add a radius.
This is only possible for a continuous line.
Have look at this video
Thank you so much, appreciate it. After your tips I achieve what I wanted.
@KRoser_12 wrote:
I know fillets and loft feature dont go together to much ...
I cannot say that I've experienced that!
The reason for that is that you included fillets in your sketches and then used the wrong loft settings.
So keep the fillets out of the loft profile sketches to keep the edges sharp. Then the loft is very simple and the loft setting I talked about is irrelevant.
Then you'll also have no problems filleting.
Thank you so much for tip, sound interesting. I just tried it with my model posted above, when I do loft with shar edges and the fillet them it seem to work ok.
So than you so much, something new to me.
