normal to plane view in drawing
Hello Fusion 360 Community!
I have a 1 tricky question.
I have a plate which normal to surface is to the angle of Z axis. When I move to drawing, standard views do not let me to choose normal to surface view. In consequence I do not have true dimensions of that plate. I want to export it as dwg file in order to mill it.
Piotr
HughesTooling
In the model workspace select the face of the plate then click Look At from the toolbar at the bottom of the screen. Next right click Named Views in the browser and create a New View and name it then save the file. Now when you create a new drawing or view you'll be able to pick your named view from the list of orientations.
Mark
Mark Hughes
Owner, Hughes Tooling
Thank you!
Works perfectly. This is a functionality which I was expecting to find :).
Best regards,
Piotr
