NOOB, How do I make a parallelogram?
john.a.timon
Observer Observer
john.a.timon
Observer
Observer
I have been trying to figure out how to make a parallelogram in fusion 360.  I started with a rectangle, assuming I could just tweak the angles and get a parallelogram.  That does not work due to constraints.  Yet it seems to me to be the intuitive way to do it.
what am I missing?
TheCADWhisperer
Delete the Perpendicular and/or Vertical.
LeonardoBN
Hi @john.a.timon.
As you noted, a rectangle comes with perpendicular in its edges. Yes, you can delete these constraints, but you could draw the parallelogram using four lines, them add two parallel constraints and the angle.
Leonardo Brunelli do Nascimento
Chemical Engineer
