Non uniform shape (surface bowel)
Newbie and found a shape I would like to expand upon. The attached image is from a template given to me. What is the best way to create this shape? Mesh body, t-spline, solid?    I would like to learn how he did it and to make my own shapes as well. Thank you in advance - Julie
laughingcreek
Could be done with surface lofts or with t-splines.  I personally would probably use lofting.   nether approach will be easy if your starting from zero.
a_antonov
In the Surface environment, you can start with an extrusion of the profile, and then create the Patch with edge conditions: Tangent or Curvature. After that, the starting extrusion can be removed.
TrippyLighting
Don’t ever use a (boundary) patch if the geometry can be created with a loft!
TrippyLighting
I designed this using T-Splines, but in retrospect it is probably much easier to do this with surface tools.
That is really great! That is what I have been contemplating too!
