Message 1 of 9
I am drawing a part that needs a 13.5mm X .3 thread, is there a way to create this non standard thread?
Mark
Mark
Hi @mahockett,
Check out this video: https://www.youtube.com/watch?v=IpfPoA6_OWM
I hope it helps.
Cheers / Ben
Check out my video channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube![]()
Thanks Ben! That sort of worked. It made a thread profile on the part but no where close to being accurate. I can't seem to get a pitch measurement and when I tried to create a relief groove at the end of the thread it left two rows of about 1/6 of the circumference of thread. It's not a drawing I could send out for quotes.
I'm not sure what you need but here is what I know about the thread. It's major diameter is 13.5mm and the pitch is .3. The height of the sharp 60 degree V thread is .25981mm
Let me know, if I'm missing something:
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
| YouTube![]()
Thanks Ben! The root of the thread is flat, is there a way to measure the pitch to make sure it is correct? Is there a problem with the minor diameter?
Mark
Ben Korez
| YouTube![]()
Could someone be a lifesaver and make a simple ring with the following specifications.
Height: 5mm
EXTERNAL MALE THREAD: M28.5x0.6 mm 60deg
INTERNAL FEMALE THREAD to fit: M25.5 x 0.75 mm 60deg
I'm desperate,
Rob
