Non standard thread
Non standard thread
mahockett
Message 1 of 9
Non standard thread
mahockett
I am drawing a part that needs a 13.5mm X .3 thread, is there a way to create this non standard thread?
Mark
Replies (8)
Message 2 of 9
Beyondforce
Hi @mahockett,
Check out this video: https://www.youtube.com/watch?v=IpfPoA6_OWM
I hope it helps.
Cheers / Ben
Check out my video channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 9
mahockett
Thanks Ben!  That sort of worked. It made a thread profile on the part but no where close to being accurate. I can't seem to get a pitch measurement and when I tried to create a relief groove at the end of the thread it left two rows of about 1/6 of the circumference of thread. It's not a drawing I could send out for quotes.
Message 4 of 9
Beyondforce
I can see, that you haven't created your own profile.
Could please send me the thread profile with the Pitch and all the dimensions?
Ben Korez
| YouTube
Message 5 of 9
mahockett
I'm not sure what you need but here is what I know about the thread. It's major diameter is 13.5mm and the pitch is .3. The height of the sharp 60 degree V thread is .25981mm
Message 6 of 9
Beyondforce
Let me know, if I'm missing something:
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
| YouTube
Message 7 of 9
mahockett
Thanks Ben! The root of the thread is flat, is there a way to measure the pitch to make sure it is correct? Is there a problem with the minor diameter?
Mark
Message 8 of 9
Beyondforce
I have used the Measure tool and the distance between threads is 3mm. I could also see that you changed the Pitch in the dialogue box to 0.3 🙂
Btw, you can use the Fillet to make the ends of the thread look nicer and not just flat.
Ben Korez
| YouTube
Message 9 of 9
Could someone be a lifesaver and make a simple ring with the following specifications.
Height: 5mm
EXTERNAL MALE THREAD: M28.5x0.6 mm 60deg
INTERNAL FEMALE THREAD to fit: M25.5 x 0.75 mm 60deg
I'm desperate,
Rob
