Non Monotonic Loading in Event Simulation
AutoCadLTEng
Observer Observer
AutoCadLTEng
Observer
Observer
I am having an issue with applying and releasing a force to create non-monotonic loading in event simulation. I would expect the reaction force results to mirror the force curve shape but they do not.
Autodesk would suggest this is easily achieved in their page here: https://help.autodesk.com/view/fusion360/ENU/?guid=EVENTSIM-DYN-MULTIPLIER-CURVE-CONCEPT
Figure 4 shows what I need to do. I have also tried that loading scheme but to similar illogical results.
Has anyone had success with non-monotonic loading in order to quantify permanent deformation?
Setup: 0.01 seconds of event duration, 25 steps
Force application: apply load ramped, hold load, release load ramped, hold no load
Results for reaction force: shape of reaction force curve does not match force application curve
bhavani_sankuratri
Hi @AutoCadLTEng ,
Hope you are doing good! Just wanted to follow up on this, were you able to find an answer to your question, or do you still need assistance with this?
Bhavani Sankuratri | Community Manager
