No Thread in STL File
Hello im New to Autodesk
Like in the Subject i did an Thread M16x2. In Fusion it looks fine after saving as STL file and open it in Cura (tried another to) its just an hole.
Does someone know why this could be ?
HughesTooling
If you edit the hole feature in the original design have you enabled Modeled Threads?
Mark
Mark Hughes
Owner, Hughes Tooling
Ups yes this was my fault.. now it works! thank you very much Cat Happy
schneik-adsk
As a tip...
If you have many holes switching them one by one can be tedious.  There is a new option in Document Settings node in the browser that lets you override all threads in one go.
Note, you must have threads in your model for this option to appear.
Kevin Schneider
Very helpful, thank you!
DeanPrecision
Thanks this solved my problem as well!
