No sweep dialog
No sweep dialog
No sweep dialog
I'm trying to learn to use the Sweep feature. If I select a path, then Sweep, then a face, it does perform the sweep. But never do I see a Sweep dialog box as I see in tutorials and related discussions here. So there's no way to select a guide rail or change the orientation, for example. Even "edit feature" after the fact does not produce the dialog.
Anyone know what's going on?
Thanks.
/Daryl
HughesTooling
Try resting the layout.
Mark
Mark Hughes
Owner, Hughes Tooling
Yup, that did it, thanks. (I did actually try to look to see if it was off screen but couldn't find it.)
/D
