Hi folks,
I created a thread and a nut but the thread of each of them interacts when I do a sectional analysis. Anyways to edit this?
Any help much appreciated. Thanks!
Solved by g-andresen. Go to Solution.
Solved by jhackney1972. Go to Solution.
You have a bigger problem that needs to be solved first. The video will explain the problem and a solution. Later in the video I will add the thread clearance which you can change if you like. Model is attached.
John Hackney, Retired
