no projects selectable bug
cekuhnen
Mentor Mentor
cekuhnen
after the last update Fusion does not show any projects anymore
the dashboard area is blank!
I signed out and singed in
I restarted the app to fix it
Claas Kuhnen
Faculty Industrial Design – Wayne State Universit
Chair Interior Design – Wayne State University
Owner studioKuhnen – product : interface : design
innovatenate
Autodesk Support
Autodesk Support
You may try using the Clear User Cache command the next time you run into this issue.
I hope that helps! Thanks!
Nathan Chandler
Principal Specialist
cekuhnen
letting Fusion run also fixes the problem.
What remains even after a cache clean is the fact that opening the pull down menu takes 4 to 6 seconds each time you click it.
This is driving me nuts when I have to browse through student projects!!!
Claas Kuhnen
innovatenate
Autodesk Support
Autodesk Support
How many projects are shared with you? Also, how large is your the ~/Library/Application Support/Autodesk/Autodesk Fusion 360/BrowserStorage_login.dat file?
Nathan Chandler
cekuhnen
It is a pure OS X problem - same on imac and macpro.
but with windows on macpro all is fine.
I have no "/BrowserStorage_login.dat" in "~/Library/Application Support/Autodesk/Autodesk Fusion 360/".
Claas Kuhnen
innovatenate
Autodesk Support
Autodesk Support
I think you have to drill down into an ID folder unique to the user located inside of the Autodesk Fusion 360 folder to see the browserstorage_login.dat file. Sorry for the confusion.. 🙂
Nathan Chandler
