No of Components
No of Components
NaRM07
No of Components
NaRM07
I am designing something with a lot of nuts, bolts and washers of different sizes. It is kind of jumbled up and I have to go through one by one to find out how many no of the same component is added. Is there any option where we can find this easily?
hamid.sh.
1. In Design workspace instances of the same part are numbered within the Browser, but sometimes they can get messed up (e.g. if you delete a pattern from timeline still counter may continue with the number after the last instance created by the pattern). Also still you'll need to look for the last number:
2. The better option in Design workspace is to use Select > Selection Tools > Select by Name. If you enter a unique part of your component's name you can select all of its instances; After hitting OK  in the right bottom corner the number of selected components is reported:
3. A different option is in Drawing workspace > Tables > Parts List. It gives you quantity of each part in your assembly:
Hamid
NaRM07
Thank you so much.
