Nintendo switchPro controller into fusion360
potlsnekkeri
Message 1 of 30
potlsnekkeri
Hello
Is it possible to upload a model of a nintendo switch pro controller into fusion.?
if so where to find a model??
i will make a holder for it on my cnc
Replies (29)
Message 2 of 30
potlsnekkeri
Anyone??
Message 3 of 30
laughingcreek
yes, you can import supported file type.  a mesh file (.obj,.stl)will be of limited utility to you.  if that is what you have the then a mesh editor like mesh mixer or blender might be a better tool.  a step file would be better (.step or .stp).  if the quality is decent you will be able to use it easily, if it's not, might require some work.
don't know where to get a model.
Message 4 of 30
whittakerdw
Yes it is possible to upload a model. I just googled Nintendo Switch Pro controller STEP file and multiple websites came up. The first one that came up was GrabCAD, which I am familiar with but you have to have an account to download anything off of the website. I am not familiar with the controller itself so I wasn't sure exactly what I was looking for so I was going to have to let you do the searching, but yes it is possible. It doesn't necessarily have to be a STEP file, that was just what I was looking for.
Message 5 of 30
potlsnekkeri
thanks i will look what i can find,thanks for helping:-)
Message 6 of 30
potlsnekkeri
i have got i stl file of the controller now
Message 7 of 30
potlsnekkeri
ok  now i got it into fusion.
i want to make a holder like that on in the pictures above,my plan was to use. this model and a woodblock and use the combine mode to get some grooves in the woodblock from the controller :-).
do i have to do something with the stl file before i can use it in fusion??
https://a360.co/3HCMEpC
Message 8 of 30
whittakerdw
If you are just using the outline of the controller and combining it with the wood block, you shouldn't have to. Is it not allowing you to combine the controller and the block?
Message 9 of 30
whittakerdw
Also you said you are making a holder like what is shown in the pictures above but there are no pictures attached, just a hyperlink of the controller itself.
Message 10 of 30
potlsnekkeri
img in the first post
Message 11 of 30
potlsnekkeri
okay i have now just tyed to combine that model ,but i cant select it?
and i also think the model is larger. then it shoud be??
take a look.
https://a360.co/3HE9uNi
Message 12 of 30
whittakerdw
Sorry about that, completely forgot about that picture. At least how I would approach this, I would get the controller centered in a good spot, then sketch a rectangle the desired size and extrude it to the desired thickness. From there, I would move the controller to where the controller is into the block about however deep you want the handle cutouts to be, and I would create an offset plane on the top face of the block. I would use that plane to split the body of the controller and make the top part invisible. I would then make the block opaque and do a section analysis about halfway for the first handle you choose to design for where its cutting into the wood, and design how it needs to be routed out, do the same for the second handle, and anything else you choose to have in the wood block. You, or anyone else, may have an easier approach, that's just how I have found things easiest so I am able to see exactly where I need to project the handle onto the piece of wood in order for me to create my sketch.
Message 13 of 30
laughingcreek
fusion is a brep modeler.  you have a mesh file.  a very dense heavy one at that.  there is little you can do with it in fusion.
if you have the time to wait for fusion to think between operations you can do the following-
-create your solid block and position relative to the controller
-convert the block to a mesh (tessellate in the mesh environment
-use combine in the mesh environment to cut the shape of controller from the block
Message 14 of 30
whittakerdw
I do believe it is bigger than it should be unless your hands are massive. I am getting that it is 60"x22"x40". You could get measurements off a controller you have and try to scale it down or try to find another model.
Message 15 of 30
laughingcreek
when you use the cloud conversion,  fusion assumes a unit of centimeters .   don't know why they thought this was a good idea, why they haven't changed it, or if they will ever change it (probably not).
it's probably off by some factor relating to a conversion, such as cm to mm or inches to mm
using insert mesh  from the insert menu will let you specify the units-
Message 16 of 30
potlsnekkeri
ok now i think i have it in rigth size ,but can anyone help me out to get it combined with the wood?
https://a360.co/3XYeIc4
Message 17 of 30
potlsnekkeri
can you show me what you mean ,i dont get it:-)
Message 18 of 30
potlsnekkeri
ok now i have the wood and kontroller like i want it to stay in the woodbrick,but i cant combine the two ??,
Need some help with it
her is my file: https://a360.co/40cqlOA
Message 19 of 30
potlsnekkeri
Anyone that can help me out here?:-)
Message 20 of 30
TrippyLighting
It really depends on what the intended end result will be. With "end result" I mean the physical artifact you intend to make. IF you can explain that, then we might be able to help.
If you want to accurately reverse engineer the mesh geometry of the controller into a usable CAD model e.g. BRep or NURBS geometry, that is something I would not recommend you attempt.
