Newbie question: creating a specific angle pyramid
Message 1 of 12
Hi guys,
I'm new to Fusion 360 but have some experience with other more mundane 3d packages. I want to make a pyramid that has a flat top with two conditions I can't figure out:
- I want the angle of the base going upwards to have a specific angle (most important)
- I want to be able to set the height of the pyramid (less important
Does anybody have any tips for a new user?
Example of such a pyramid:
Accepted solutions (3)
Replies (11)
Message 2 of 12
davebYYPCU
On the basis that you know those particulars,
use Extrude for the square, with (known) taper angle, the height as you wish.
Might help....
Message 3 of 12
Thanks for your reply! It doesn't quite work the way I expected it would.
I get the below:
While I am looking for a 76 angle on the slope like:
More ideas are welcome 🙂
Message 4 of 12
HughesTooling
Have you tried setting the taper to 90°-76°? So 14° taper.
Mark
Mark Hughes
Owner, Hughes Tooling
Message 5 of 12
davebYYPCU
Use -14 degrees.
90 - 76 = 14.
Message 6 of 12
Ah, totally wrong logic. Thanks a lot!
Message 7 of 12
chrisplyler
Yeah, the taper angle is in degrees off of the extrude direction. It's a bit curious - once you saw it was way too steep - that your brain didn't immediately have an "aha" moment.
But I won't hold it against you. With increasing frequency as I age, I'll cruise right on past my highway exit and won't realize it for a few minutes.
Message 8 of 12
MoshiurRashid
Simple, be analogue to get more control. See this easy procedure by which you will get more control using a little bit of more time.
https://autode.sk/32xN89K
Moshiur Rashid
Autodesk Certified Instructor
ACP | CSWE
https://www.autodesk.com/expert-elite/overview
LINKEDIN | FACEBOOK
Message 9 of 12
TheCADWhisperer
Put down the doughnuts while driving.
Message 10 of 12
chrisplyler
It may or may not be a coincident that the doughnut shop is a few minutes past my usual highway exit.
Message 11 of 12
Haha that explains it 😉 For me it's that I'm learning this program in my evening hours, during which I find I am not the sharpest XD
Message 12 of 12
Very nice alternative technique, I feel spoiled. My thanks 🙂
