Newbie needs help: Add three holes to an existing design
kojaklazy
Message 1 of 8
kojaklazy
I have to add three holes that are equally spaced from each other on a cylinder surface.  I have no clue on how this is accomplished and I am not sure if I can do it with my fusion version (NON-PAID)
Replies (7)
Message 2 of 8
davebYYPCU
Create first hole by preferred method.
Circular Pattern - select the Feature (that made the Hole), select cylinder axis, the default is for a 3 count.
Might help…
Message 3 of 8
TheCADWhisperer
@kojaklazy
Are there any unresolved issues highlighted in your Timeline?
Does Ctrl b or CMD b on Mac return any errors?
Check back in a few minutes for corrected file.
Message 4 of 8
TheCADWhisperer
@kojaklazy
I didn't know how you wanted the circular pattern of three holes located relative to the rectangular pin feature, but that can easily be edited.
See attached.
Edit Sketch 1 and examine carefully.
Message 5 of 8
kojaklazy
From what I can see from the cad file it looks good.  I will print the bottom portion of the adapter and check the alignment.  I will send you a response as soon as I check the print.
Message 6 of 8
kojaklazy
The holes are in alignment based on the current diameter/circumference.  Can you increase the diameter of the base from 92mm to 93mm (1mm increase)?  I am also guessing the distance between each hole will also need a slight increase due to the circumference changed.  Thank you in advance.
Message 7 of 8
g-andresen
No!
günther
Message 8 of 8
kojaklazy
Günther,
Thank you for the explanation.
