Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
(newbie) Cutting part from body
3 REPLIES 3
342 Views, 3 Replies
Hi everyone,
I am a newbie, having started with Autodesk Fusion 360 about a couple weeks ago, designing various simple models which would help me create a custom PC case. things are going well, but I inevitably stumbled upon a rather simple issue which I can't figure out how to resolve.
I am modeling an Aquacomputer High Flow Sensor which I own (in physical form), and it has some nicely cut edges I would like to model. However I can't, for the life of me, figure out how to remove/cut the corners, which cover all three dimensions. In the attached screenshot I have selected the area which needs to be removed. I need to apply this to all four corners, and I have sketched all areas I could think of.
Area to cutArea to cut
There must be a simple step to be performed, but as a newbie I wasn't able to figure it out. I have attached the archive as well.
Thank you in advance for your priceless advice!
Eduard
Hi everyone,
Eduard
Tags (2)
3 REPLIES 3
g-andresen
g-andresen
Hi Eduard,
it´s this what you want?
günther
Hi Eduard,
günther
in reply to: g-andresen
Thank you so much! I never used the Sweep operation before, now I have integrated it in my expanding knowledge.
I very much appreciate your help, this is indeed what I needed. My model is now complete 🙂
Thank you again!
Thank you again!
chrisplyler
chrisplyler
@Anonymous 's method is MUCH better, but here was my shot at it...
Screencast will be displayed here after you click Post.
e87ece79-bc3b-48a0-91c5-34dadf721f30
