05:28 AM
Greetings all. Experienced 3D visualiser, but absolute F360 NEWB:
Aim:
I want to make a radial array of 6 columns (cylinders) with a Y up orientation. I then want to be able to rotate the original cylinder on the Z axis and have all other cylinders in the pattern to rotate to match ( as 'instances'). The original cylinder was set up as a component and moved to X = -100.
What would be the the correct approach for this please?
