Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Problem in design
2 REPLIES 2
235 Views, 2 Replies
Problem in design
HI
I have a fusion assembly design in my system with some 40 component, and there are no linked components in that design, but still the assembly is showing the symbol of " Get latest Component" , and i am unable to find a solution as of how to get through this, so kindly solve this ASAP.
2 REPLIES 2
TrippyLighting
Kindly share your model please.
ahsan.autodesk
Hi @Anonymous,
Is it possible your local components in your assembly may themselves have references/links to external components? The out-of-date icon that you see will also show up if any indirect references are newer. One quick way to find out if you have external references (either direct or indirect) is to execute the File->Export command. It'll fail if the assembly has external references.
Ahsan Ali
Fusion Senior Software Architect
Technology Administrators
