New to Fusion360 Need help with sheet metal work around
Message 1 of 15
20170425_122745.jpg20170425_123535.jpg20170425_143724.jpg20170426_035746.jpg20170426_040531.jpghttp://a360.co/2pIzhxi
Hey there guys and girls,  I am new to the whole 3d modeling game and am attempting to implement fusion360 into my current work.  Decided to try to model an intercooler endtank that I had just made a couple days ago by hand.  Im running a CNC plasma table to cut out my plates prior to forming and welding so I am attempting to find a way to model the component in fusion and split it to generate a DXF for a flat part.  If anyone has any tips on how to do something like this or can point me in the right direction for this type of project it would be greatly appreciated.  Thanks!!
-Dan
Replies (14)
Message 2 of 15
screenshot.pnghere's a quick screen shot of my attempt at modeling the part after having already made it by hand
Message 3 of 15
TheCADWhisperer
Those are some good looking weld beads.
Message 4 of 15
Thanks for the reply!!
I can use the welder OK just not the computer hahaha.  Let me see if I can export this properly.
Message 5 of 15
TrippyLighting
Beautiful!
@brianrepp can we sign this gentleman up for the sheetmetal preview ?
Message 6 of 15
TheCADWhisperer
I recommend that  you sign up for the Sheet Metal Beta (I don't have it, but something similar to this is how I would model in Inventor or SolidWorks).
Message 7 of 15
thanks guys!
Top Daug, I think you are losing me on the delete face step that you have.  Still extremely new to the software im kinda sorting my way through the tools.
Not sure if I have enough experience with CAD to be in the BETA testing arena for sheet metal but I am definitely more than willing to give it a go.  I have the thread open right now going to add myself in as soon as I finish up what I am working on right now.
Message 8 of 15
that would be awesome.  Not sure I have the required expertise but I am more than willing to see what I can do with it.  Im guessing that the sheet metal beta testing thread is locked as I cannot see a way to post a reply there at the current juncture.
-Dan
Message 9 of 15
TheCADWhisperer
@Anonymous wrote:
... you are losing me on the delete face step that you have.  ..
Not sure if I have enough experience with CAD to be in the BETA testing arena for sheet metal ....
Shell will often return incorrect results where cut side is not perpendicular to the flat.
Delete Face and then Thickens ensures that the material is uniform thickness with cut sides perpendicular to the flat.  (the sheet metal tools would automatically generate the Flat Pattern for you - but not sure if they will support multi-body)
They love to have novices involved in BETA as experts always do things "right" and miss the issues that novices will find.
Message 10 of 15
Not sure what I have wrong there but when I try to delete the lower face this is what I end up with.  Looks like its continuing the 4" radius fillet.
I also cannot find the trim tool that it looks like you used to separate the 2 panels.  Bear with me here, Im a 2D guy entering into a 3D world.
Trust me sir I will find myself in areas of the software I definitely should not be.......
Message 11 of 15
TheCADWhisperer
I also cannot find the trim tool that it looks like you used to separate the 2 panels.  .
You must enter the surface modeling (Patch) workspace to find the correct Delete Face and Surface Trim tools.
Message 12 of 15
You sir are my hero!  once in the patch work space everything worked out perfectly.  Now to find a way to get it all flattened out and I am in business.
Message 13 of 15
promm
@Anonymous,
I added you to the sheet metal preview.  Later this month the preview will get the ability to flatten a sheet metal model.  I sent you an email with more details, let me know if you have any questions.
Cheers,
Mike Prom
Message 14 of 15
promm
@Anonymous,
BOOM, Mic drop
Dan I sent you the file.
Cheers,
Mike Prom
Message 15 of 15
OrhunUnal
I wonder did you model from the beginning or used convert to sheet metal tool?
