new to fusion joint assembly, basic question
Message 1 of 14
I am trying to mate piece 1 to the holes in piece 2 and 3. Piece 2 and 3 are both revolving in the plane shown, and piece 1 was created based on a distance between these holes. How do I attach piece 1 to both of these holes, I keep getting an error when I try to do two revolute joints.
Replies (13)
Message 2 of 14
davebYYPCU
Check that all pieces are faces parallel, with perpendicular holes, alignments are required to be perfect.  Fudging with Cylindrical Joints might help with that.
Parts 2 and 3 are free to rotate, on there current fixing positions, if locked or with limits, can’t align to 1, might be the trouble.
Attach the file, for better than guessing.
Message 3 of 14
I attached the file. I believe everything is parallel. Still not sure
Message 4 of 14
Nevermind I think I found the issue. thanks
Message 5 of 14
davebYYPCU
But not flush.
Camera icon not working today
Might help.....
Message 6 of 14
fleming.kyle.william
Try using a cylindrical motion.
Quick Demo of Cylindrical Motion
Message 7 of 14
davebYYPCU
Are you saying,
Don't worry about model alignment errors, because Cylindrical works?
Wow.
Message 8 of 14
Alignment inherits from the joint object. You don't need the pins, but I thought it would help for clarity.
Please refer to community etiquette. We're all here wanting to share and include.
Message 9 of 14
davebYYPCU
Are you saying,
Message 10 of 14
No. That's not what I'm saying at all. Nor is it pertinent to the initial question. "How do I attach piece 1 to both of these holes, I keep getting an error when I try to do two revolute joints."
Try a cylidrical joint.
***Please refer to community etiquette. We're all here wanting to share and include.***
Message 11 of 14
@AnonymousWhen you find a resolution to your issue. Please choose an accepted solution, even if it is your own.
Message 12 of 14
TheCADWhisperer
When I open your "solution" that you attached -- it does not appear to be correct to me?
Message 13 of 14
Initial question: "How do I attach piece 1 to both of these holes"
If the question is about model alignment and kinematics please state so.
Message 14 of 14
davebYYPCU
He found his problem - misaligned faces - his revolves are working,
refer to message 2 above, Cylindrical fudge works, but doesn't fix his alignment problem.
