New to fusion 360…help with dimensions of uploaded drawing
farrarcalvin
Message 1 of 8
farrarcalvin
Need help. We took a pic of a template we drew on poster board. We uploaded image to canvas and are currently stuck on scaling the image. How can we properly scale the image, it also includes an ellipse at the bottom. We are struggling getting the same dimensions as our template. Any advice would be helpful! Is there any technical support that we could utilize that could take control of our computer and see what we see?
Replies (7)
Message 2 of 8
g-andresen
Please share the file.
File > export > save as f3d on local drive  > attach it to the next post
günther
Message 3 of 8
farrarcalvin
Here you go
Top Line is 8.5 inches Wide
Length of both sides is 15 inches
The Width of the arc from point to point is 20.5 inches
From Top Center of arc to top of (8.5 inch) line is 11.25 inches
Message 4 of 8
farrarcalvin
Reply is below sorry
Message 5 of 8
Bunga777
Put the dimensions into the sketch with the correct dimensions and the sketch you drew on the canvas in this way.
The name of that dimension is used to calculate the scale.
Now all that is left is to move the Canvas and you are done.
Since distortion cannot be corrected to a certain degree, the limit is to match to a certain degree.
We have made a video of the event, so please enjoy.
https://knowledge.autodesk.com/community/screencast/246f4f23-1ccd-4bfa-a222-ae3b29f0ba14
Message 6 of 8
farrarcalvin
Wow, very thankful for your help. I’m a fifteen year old kid trying to teach myself and I’ve already learned a lot. Thanks so much.
Message 7 of 8
davebYYPCU
.Blue and orange sketch articles should keep you awake.
Fully constrain the sketch until all is black (in your case)
Constrain to Origin, and an angle dimension on a top corner should do it.
Might help....
Message 8 of 8
Bunga777
Thanks @davebYYPCU  for the advice.
In this case, what is missing from the full definition is the vertical positioning of the sketch.
If we put the dimension from the origin to the top edge as 6.0in as a hypothetical, it will be fixed.
Actually, I did not dare to fix this dimension.
Because if I changed the scale of the canvas, it would not match the position of the sketch, and I was thinking of the possibility of adjusting the position by adding the dimension later.
However, as I did it, I realized that I could freely move the vertical position of the canvas as well, so it turned blue as it was. My apologies.
As @davebYYPCU says, it is less trouble if all the sketch lines are black, so I strongly recommend you to fully define them and make them bla
