Nested timline groupes
linusb55PT2U9
linusb55PT2U9
Community Visitor
Community Visitor
Hi. I'm learning how to make more complex assemblies in Fusion. Right now, I'm trying to make a therderd electric buggy, and I've just finished one of the wheel assemblies. Each of the parts of the assembly is grouped in the timeline. Is there a way to group all the groups together?
Drewpan
I would strongly recommend that you do the embedded tutorials in the Fusion Documentation
and also some of the Self-Paced Learning to help you to learn fusion faster and better. They
can be found here:
It is also much easier for the forum to help you if you attach your file AND a screenshot of
what you want to achieve and what the problem is. You can create a file to export like this:
Time spent on the tutorials and self paced learning will not be wasted. Also check out the three
RULES that are pinned to the forum for further guidance.
Cheers
Andrew
laughingcreek
no.  timeline grouping function is fairly unwieldy.  proper use of components is the best way to organize the timeline.
