I want to create a simple negative curved radius on a edge of an oval base but cannot seem to do it. Do I have to do it in the manufature section or can I do it in the design module?
This is what I am trying to do...
Solved by wersy. Go to Solution.
Solved by davebYYPCU. Go to Solution.
Solved by TrippyLighting. Go to Solution.
Sketch the ellipse/oval.
Extrude it.
Use the pipe tool on the upper edge of the extruded shape.
Done!
