Need to make multiple bodies then make each into individual components.
custombuilt15
custombuilt15
Hi all
I'm new to Fusion (coming from Solidworks) I'm trying to model up a barn door that has many different tongue and groove boards running down the center. Each board needs to be a different length and each end has a 45 degree cut on it. Ideally what I would like to do is create one tongue and groove board with the 45's already on it. Then duplicate it and just change its length, but I'm having a tough time figuring out how to do that. Any suggestions or a better way would be greatly appreciated.
Ken
lichtzeichenanlage
I would do it by not "Copy/Paste" the component but "Copy/Paste New" the component. I've created a little screen cast to show "trick":
lichtzeichenanlage
Perhaps I should add some more comments:
As you can see, my workflow starts by creating a component. So every thing is nicely packaged and could be handled like described in Rule #1. You can not use User Parameters for this, because those would change again all components regardless you used "Paste" or "Paste New".
custombuilt15
This is perfect thank you lichtzeichenanlage for taking the time to help me out! I really appreciate it.
Hey thanks for this! I am new to this and working on building our new bed! This helps a lot!
etfrench
Here's what I think of when you say tongue and groove:
ETFrench
