need some help with animating a tricky joint
Will1337
Will1337
i cant seem to figure out how to get these joints to work together. Should i be using the pin-slot joint?  is there a better way to do an increasing diameter slot joint? would you even call it that?
davebYYPCU
You were fairly close, Ground the back plate,
motion Link the rotation with the slider distance, these numbers are close to it, might need further tweaking.
Will1337
Thanks again!
