Need help with the Circular pattern
Ingars.Kursitis
Message 1 of 9
Ingars.Kursitis
I got problem with circular pattern feature. I am trying to circular pattern this feature(Picture 1). But due to the fact that my part isnt full round is there a way how to make sure that the feature adjust the height of the surface. At the moment I am getting this sort of feature(pic 2) which I dont want, I want them to be flat as intended.
I do understand why its happening. But dont know how to fix it or what to use. Any help is highly appreciated. My part goes around but got like sharp surfaces which doesnt make it perfectly round.
Replies (8)
Message 2 of 9
jhackney1972
You need to attach your model.  Open>Edit>Export and then attach to a reply post
John Hackney, Retired
Message 3 of 9
Ingars.Kursitis
Sorry very new to this forum. Please don't mind the mess in terms of the structure.
Message 4 of 9
Ingars.Kursitis
Perfectly I would like to extend those blops into this area
Message 5 of 9
Ingars.Kursitis
For sake of it I tried it on the top where surface is perfectly round. Is there a way how to achieve same effect at the bottom part where surface is varying due to the geometry.
Message 6 of 9
jhackney1972
I used the height of the bumps before the pattern.  See if the attached model suits you. If you want them longer, change the length from the surface in the original.
Edit: You are correct, your timeline shows a lot of errors.  Correct these when they occur to make modeling easier.
Message 7 of 9
Ingars.Kursitis
They are levitating in the blank space I get what you mean by increasing the size of them, but I want to keep them small size. Thanks for your time appreciate the effort.
Message 8 of 9
jhackney1972
Sorry about that, I did not notice the separation from the other surfaces.
Message 9 of 9
etfrench
Do one panel, then circular pattern that panel.
ETFrench
