Need help with marine engine piston movement
Message 1 of 50
So i was doing a small project for my school and i was doing a piston movement animation.
As the piston rod move downwards, i need it to revolute at the bottom.
I cant seem to get it to work. Any idea?
I am new to fusion 360.
Replies (49)
Message 2 of 50
Beyondforce
Please attach the file so we can help.
Ben.
Ben Korez
Fusion 360 NewbiesPlus
Fusion 360 Hardware Benchmark
| YouTube
Message 3 of 50
Message 4 of 50
Beyondforce
First thing first!
1. You forgot R.U.L.E #1. You to apply it!
2. There are some warning which you must fix before you move forward!
3. Remember to build all the parts in-place!
4. You didn't have to slice the Cylinder house into two pieces. You could have just use the "Selection Analysis"
When you are done correcting the above, please let me know.
Cheers / Ben.
Ben Korez
| YouTube
Message 5 of 50
(1. You forgot R.U.L.E #1. You to apply it!)
Sorry i am abit new to this, so i need to group the different parts in different components and name them?
Where do i see the warning? I also try to undo when there is error
Hmm... I tried to put the parts in the location i need them or am i doing it wrong?
What does selection analysis do? The cylinder cover(house) was cut by my friend when he show me how to use fusion 360 to show the inside of the cylinder in the animation later on. I wish this is not an issue later on. So i need to combine both of them together?
I tried to fix the issue u asked me to but i am 99% sure i did not do it properly.
can u help me check and tell me the stuff i need change. Thanks for the help Ben!
Message 6 of 50
Beyondforce
Here you go:
Ben Korez
| YouTube
Message 7 of 50
Thanks for the video, really helps a lot. One thing i still don't get it is the "in-place", can u elaborate more on that? Thanks for the fast respond and great explanation
Message 8 of 50
Beyondforce
In-place means, you create the parts where they need to be (in relation to each other) and not separate from each other. This way, you will only have to use the As-Built Joint.
Ben Korez
| YouTube
Message 9 of 50
So the top part i did it correctly? Since it looks like its in place. Really thanks for the help and advice. I will try to finish it up monday.
Message 10 of 50
Beyondforce
The last time I checked it wasn't in place and the pin neither. But the rest of the parts were in place.
The model look pretty good, you just need to rebuild it correctly this time and then we can work on the joints and animation.
Ben Korez
| YouTube
Message 11 of 50
Alright thanks alot. Will remade it asap. Thanks!
Message 12 of 50
davebYYPCU
Just a quick note,  as you are starting over,
most engines do not have the Conrod connected to the main bearing as you appear to have it.
When rebuilt, connect the rod to the small pin,
or reverse the sizes of the shafts in the crankshaft, large axis for the bearing of the crank, and small axis connected to the rod, is more appropriate in the real world.
As if I didn't have enough to do ... eh?
Message 13 of 50
Did you mean it should look like this at the main bearing?
Message 14 of 50
davebYYPCU
Yes, in your file you have plates holding a large shaft and two small shafts,
In the photo you will see the large end of the plates are used as counterweight, and are not connecting to the connecting rod for the piston.  The photo also shows the main "crankshaft" is in the mid point of your plate, or said another way,
the heavy end of it has no connection, the small end of the plate would normally connect to the rod. And bearing connects to the mid point of the plate.
But it is your model to do as you see fit.
Message 15 of 50
Thanks for the explanation but this project is just a demonstration that cylinder movement will produce sound so it was never to be a real product but if i got time i will do that.
As i was taught only the basics about the cylinder, i don't even know that crankshaft was built that way. Thanks for letting me learn something. 🙂
Basically i am just doing a very simple version only but not as simple as i thought.
Message 16 of 50
http://a360.co/2h5KS3W
I finished remaking the piston. Do tell me if i have any problems with this one and i will try to fix it.
Message 17 of 50
Beyondforce
Hi @Anonymous,
The model looks much better now. I'm assuming that's what you need?:
Ben Korez
| YouTube
Message 18 of 50
Omg, thats what i wan, thanks. Can u show me how to do it?
Only the small circle at the end should not move, the Connecting Crankshaft is rotating at the opposite direction of the piston.
Message 19 of 50
I have updated the drawing so the End of Crankshaft is in a new component. That is the center point of rotation, and if possible can u rotate it when the piston is moving?
Message 20 of 50
Beyondforce
If you have any question, please let me know. Here you go:
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
| YouTube
